Results 1 to 8 of 8
    Forum Regular Registered Member RH Customs's Avatar
    May 2006
    Spring, TX
    Cool Choosing and affordable Subwoofer cable...
    I need help in choosing and affordable subwoofer cable. Right now I'm running a cheap cable from Radio Shack. My question is what is a good subwoofer cable under $30 for a a 10 foot cable?
    Thanks
    RH
    Suspended superpanavision70mm's Avatar
    Jan 2006
    Pittsburgh, PA
    I was going to recommend www.cobaltcable.com.....however, a 10ft sub cable is $60, but would be well worth spending twice what you had in mind. Any chance you can increase your budget a bit?
    Check out this site too (they are in your price range)
    http://www.ramelectronics.net/html/sub_cables.html
    May 2006
    Spring, TX
    Wow RAM has some exellent cables, I think that is where I'm going to get the sub cable as well as upgrade some of my other.
    Thanks
    For the link.
    RH
    Jan 2006
    Pittsburgh, PA
    No problem....i've ordered some from them before for other people and they have been all great cables for the price.
    May 2006
    Spring, TX
    Also are there other cables good quality. I was also thinking of upgrading all of my other cables? ( stereo RCA's , component, etc.)
    Thanks
    RH
    Santa Claus Registered Member
    Feb 2006
    North Pole
    Quote Originally Posted by RH Customs
    Thanks
    RH
    Since your sub is going to be 10' away I would highy recommend the Monster SW200 surge protector because with it's stage 1 clean power curcuitry it we'll improve the subs preformance tremendously over an ordinary sub cable alone.Look it it up as there are many reviews of people that swear by it.I think it's about $28 now.
    May 2006
    Spring, TX
    I don't think I need that, I'm running it of a Monster Cable Home Theatre PowerCenter™ HTS 800. I also went with MonsterBass™ 300 Subwoofer Interconnect 12ft . And the sub that I have is a B&W ASW 300.
    Thanks
    RH
    Jul 2004
    blue jeans cables!
