Results 1 to 4 of 4
    Dec 2004
    Question Bose Lifestyle 28 Home theater audio cable
    Help please with wiring Bose Lifestyle 28 Home theater audio cable !!
    I have loose Bose audio cable that connect's AV 28 media center with PS18 Acoustimass module
    This cable is similar in Bose Lifestyle 18, Bose Lifestyle 28, Bose Lifestyle 35, Lose lifestyle 38, Bose Lifestyle 48
    It have RG45 connector at one end and Mini din 8 connector at another end.
    Please !!! If anybody have Lifestyle system send me please wiring of this cable !!
    New audio cable from Bose cost's too much $$$
    Rg45 connector Pin's -
    http://www.beveiligingsshop.nl/media/rj45.gif
    Mini din8 connector Pin's -
    http://www.gpsy.com/jp/manual/images/MiniDin8.gif
    for example :
    RG45 --- Mini Din 8
    Pin 1 --- ?
    Pin 2 --- ?
    Pin 3 --- ?
    Pin 4 --- ?
    Pin 5 --- ?
    Pin 6 --- ?
    Pin 7 --- ?
    Pin 8 --- ?
    Thanks so much.
    Forum Regular vr6ofpain's Avatar
    Jul 2004
    Town, State
    This would be a good time to ditch the bose.
    Suspended markw's Avatar
    dunno, but perhaps a little work on your part might help.
    With an ohmmeter or a continuity checker you could trace out the wires. You might need to invest in a couple of female jacks for both sides to give you more working room, but it might be worth it.
    Last edited by markw; 01-20-2005 at 06:53 AM. Reason: It's "female", not "famale". I really outta proofread before I submit.
    Mar 2005
    I have Lifewstlye 25 whose 13-pin plug became damaged. In repairing it, I can make the following observations on your behalf:
    You will find the configuation for the mini-DIN in the PDF Bose manual, Technical Information page.
    RG45 Mini DIN 8 13-Pin DIN
    Pin 1 --- Variable L audio
    Pin 2 --- Variable R audio
    Pin 3 --- Fixed L audio Pin 9
    Pin 4 --- Fixed R audio Pin 1
    Pin 5 --- Audio ground Pins 5 & 2 (see note below)
    Pin 6 --- +10v control line Pin 7
    Pin 7 --- SMART SPEAKER DATA Pin 12
    Pin 8 --- Control Line ground & remote antenna Pin 8
    RCA Phono for DVD surround Tip Pin 4
    Screen Pin 3
    You will find a drawing of the 13-pin DIN plug on http://www.maplin.co.uk/Media/product_pdfs/JW95.pdf
    I have taken the pin numbers to represent pins viewed from outside (male) on the 13-pin DIN plug
    The cable connected to pins 8 (screen), 12 & 7 was a twisted pair screen.
    The two audio cables were single core screened Pin 9 screened to Pin 5 and Pin 1 screened to Pin 2
    The digital audio was connected to an RCA Phono via a single-core screened with pin connected to Pin 4, Screen to Pin 3
    They are not much fun to solder into place
  1. Replies: 13
  2. Review of Bose 901s
    By sam_pro in forum Speakers
  3. Setting up a Home Theater - any help is appreciated n-n"
    By yucheng in forum Home Theater/Video
    Last Post: 01-14-2004, 06:59 AM
