Quote Originally Posted by bfalls View Post
Stereophile had the Radio Shack hook-up wire in their Recommended Components list for many years. They don't put grades on the cables because they are so subjective. They only provide reviews from their writers.
I still have my box of Radio Shack solid core hook-up wire. The insulation is plastic and the look of the copper did not instill confidence as to it's purity. The largest gauge in solid core was 16 gauge so it would be tough to compare with the 12 gauge AntiCables. My system is much nicer then when I experimented with the RS wires. I doubt if the RS wires, if memory serves, would create the positive improvement of the AntiCables. Again I think the quality and minimal grain structure of the better wire in the AC's is what helps them sound as good as they do.
