Results 1 to 3 of 3
    May 2004
    Arrow homemade line to line 1/8th inch miniplug cable
    Hi all,
    I was just wondering if anyone had made a homemade line-to-line 1/8th inch miniplug cable from the miniplug of two sets of headphones? I'm always buying these cables for my minidisc or for my computer system and they're fairly expensive, and I was wondering if I just spliced two cheaper headphone plugs together if that would work or if the circuit is more complicated than that. Thanks.
    Jordan
    The Collector
    Sep 2003
    Springfield, MA
    it would work, but it would be a pain and it wouldn't be a good connection. if it is just 1/8" to 1/8" the cable shouldn't be expensive at all, especially if it isn't a balanced 75ohm cable for digital use. if it is just analog it would only be a couple bucks for it at any place like radio shack. if it is for a digital connection then you can still use the cheap cable
    May 2004
    buy some cable and two plugs, don't have a joint in the middle of the cable. but if you're unsure buying a pre-moulded cable would be better.
  1. bi-wiring
  2. Replies: 4
    Last Post: 04-02-2004, 02:45 PM
