I think it will be the best -- maybe!!!
So far I've built only one speaker: a centre channel that turned out pretty well ... http://gallery.audioreview.com/showp...sort=1&cat=500
But I have in mind to build a pair of 2-way monitors that will rule; (let me dream). They will employ DSP to provide:
  • Active crossover
  • Driver level matching
  • Baffle shelf compensation, and
  • Equaliztion.
The cabinet will be a closed design with a fairly low Qtc, (say .65); the DSP will level the response down close to the free air resonance (Fs) of the woofer.
Haven't decide on the drivers yet; either:
  1. Accuton C23-6 tweeter + Accuton C92-6 woofer, or
  2. Morel MDT33 tweeter + Morel MW166 woofer.
(The Morels are a bit cheaper.) Box size will depend on the woofer choice, but either of the above a suitable for closed box usage. Crossover will be quite low, 1600 - 1800 Hz, depending on driver, 24 or 48 dB/octave.
DSP will mostly likely come from a Behringer DCX2496 ... http://www.behringer.com/DCX2496/index.cfm?lang=ENG
