Results 1 to 25 of 33
    AR.com DIY crososver design
    Anybody have any info on this? Like what frequency is it set at, etc...
    Not much is said about it.
    Anybody have a frequency response plot of this speaker with the newest crossover specs?
    DIY Dude poneal's Avatar
    Sep 2003
    TX, USA
    Look like you alread built them but
    I priced the individual components and the price difference between the parts and having madisound build them was only $6 so I had them build mine (all 5). I belive the xover is around 2700
    Aug 2004
    I estimate the xover frequency to be 2,600Hz. I put the new xover (with 2Ohm resistor to pad down the tweeter a bit) into speakerworkshop out of interest. (The frequency plots are based on infinite baffle - I don't think I linked it to an enclosure so don't worry about it dropping away from 150Hz down....above 500Hz is indicative.)
    Please note - these are estimations, modelled on Peerless' published frequency and impedance graphs (not measured). also - I don't know why but I had to invert the tweeter to avoid a null @ xover (as you'll see in the xover diagram) - not the case when you build one....
    Cheers,
    David.
    Attached Thumbnails Attached Thumbnails AR.com DIY crososver design-ardiy.jpg
    Sep 2003
    TX, USA
    20ohms?
    Thats a large pad. Ed recommended between .5 and 10 I do believe. I was thinking of getting a 5 of the 2ohm as my boxes are almost complete. I sure do like that plot though. I am really anxious to get these boxes done LOL.
    Yeah, that mid-bass dip is all but gone now...man, I've got to package all my stuff up in the next 2 days...I'm hoping unpacking goes rather quickly and that I can just jump right back into these. Got the house all bought...basement should be finished by the time I arrive. I should be able set up shop faily quickly in the garage. I've still got to finish the PeeCreek's, too (might buy the Usher tweets for those and swap them to see how they hold up to Ed's speakers).
    Paul, can you recommend me a Plunge Router? Or were you the one cutting circles with a jig saw and dremel?
    Sep 2003
    TX, USA
    Get a good plunge router--one that will last you a life time. I recommend the brand I'm using which is a porter-cable (I think its 3.5hp) and an assortment of bits (straight, round over, cove, dovetail, etc.).
    My boxes are looking good. I put the second coat of primer on yesterday and will sand tonight. I think I will have to put a 3rd coat on at least one of them as I can still see that I did not sand the glue line well enough on one box. Other than that, they are as smooth as a baby's ass. I may be able to apply the first coat of enamal in a few days.
    That graph has me pumped up but I don't want to rush it. Well, your gonna be tired moving so I wish you good luck and take it easy. Easy as in don't hurt yourself moving heavy items, etc. You only got 1 back so take care of it. Later, Paul.
    Me move? No way...my new employer is covering most of that so, I've boxed up the fragiles as best I can, and I'll let the movers handle the rest...
    Porter Cable seems to be the most common one recommended...guess I'll have to grab one.
    Sounds like you're soaring...how many of these are building again? What color (or colour now, I'm Canadian again).
    Wonder if you'd have saved time veneering MDF like I'm doing? Maybe I'll try gloss black paint for Wayne J's speakers.
    Sep 2003
    TX, USA
    Yes, I think veneering would have saved time. Unfortunately, I do not know anyone who has veneered and was scared to try it on my own. I am building 5 of them. I am going for that piano black gloss look where you can see yourself in them. There was a good article on how to do this on PE tech talk a week or so ago. Ya I use both color and colour at times. I don't really think about it, it just happens sometimes. Later, gotta go back to work. Paul.
    Forum Regular Swerd's Avatar
    Gaithersburg, MD
    Hey kexodusc
    Using a jig saw and a Dremel tool was very hard for me to cut circles in 3/4 inch MDF. I went through this about a year ago. Cutting out circles was a problem until I got a Jasper Jig. Parts Express had a special on them at the time. Other woodworking dealers sell them online as well. They make the whole job of cutting the circle and countersinking a speaker easy. Before choosing a plunge router, you should check out Jasper's instructions on which plunge routers fit their jig. (I'll try to attach the file) There are holes predrilled in the jig that fit these plunge routers:
    Bosch 1613, 1615
    Skil 1823, 1825
    DeWalt 621, 625
    Fein FT-1800
    Elu 177
    Porter Cable 7539, 7529, 690 series
    All Sears, Ryobi, & Makita
    Freud FT2000E
    Hitachi M8V, TR12, M12V
    Even if you don't want a Jasper jig now, you may change your mind later.
    After reading too much about about plunge routers on the internet, and after some good advice from Dick Hertz on this forum, I bought a DeWalt 621. I like it and would recommend it. The Bosch plunge router is also well received. Here is one review of plunge routers that is worth reading http://www.taunton.com/finewoodworking/pages/w00047.asp
    There are other newer models available now that may also fit the Jasper jig. You can email Jasper Audio to ask what fits their jigs.
    Gaithersburg, MD
    The attached file didn't appear. Go to
    Jasper Audio
    3612 Mangum Road Suite 108
    Houston, Texas 77092
    www.jasperaudio.com
    jaspera@sbcglobal.net
    I bought the Model 200 jig.
    Aug 2004
    Box modelling the AR.com DIY
    .... got around to modelling the box with the 850122
    I estimate the internal box volume is 10.58 litres. With a port @ 152mm (6") length and 2" ID, that would give a tuning frequency of approx 55Hz. Attached is the modelled response of the woofer in an arbitrary box (courtesy WinISD)
    Attached Thumbnails Attached Thumbnails AR.com DIY crososver design-ardiybox.jpg
    Sep 2003
    TX, USA
    Dave, could you post the plot without the 2ohm resistor? Thanks, Paul.
    Aug 2004
    Sure Paul,
    There doesn't appear to be much difference. As expected you get a lift of a dB from the tweeter so it's a hard call. I can see why he recommended quick connects so it is easy to switch out resistors to try.
    (I was trying to link the enclosure to the graph so we could estimate the low end response but can't figure out in speakerworkshop how to do it.... )
    Cheers,
    David.
    Attached Thumbnails Attached Thumbnails AR.com DIY crososver design-ardiy2.jpg
    Sep 2003
    TX, USA
    Thanks Dave, I'm going to try it without the resistor first and then if I think its a little bright add the 2ohm resistor. I ordered them just in case. It would be interesting to see where the lower end starts to drop off but madisound has the frequency response from 45hz-20khz +/- 2db which is pretty darn good for a monitor of this size. Thank you very much for the second graph. Paul.
    Speaker city's response is the same, Wayne J's PeeCreeks which I'm also building (same 850122 woofer) have the cabinet tuned to just under 50 Hz, so I don't doubt the 45 is possible.
    MCH
    MCH is offline
    May 2002
    When I measured my speakers with test tones and SPL meter I got 38hz before they dropped off. Of course this is in my listening room environment variables. These speakers on their own have decent bass response. Saying that, I wouldn't part with my Tempest sub. I firmly believe most systems (maybe all?) benifit from a seperate subwoofer.
    Yeah, I'd agree with that, MCH. Where do you cut off your LFE's then with these? I'm thinking of a cut-off at 60Hz, or maybe a gradual crossover at around 50 Hz, but I generally prefer the cut-off.
    Aug 2004
    Hello Paul,
    I couldn't rememebr if you were making the xovers yourself. If you are ordering the xovers from madisound premade - they come already with the 2ohm resistor installed. I ordered 2 more 2 ohm resistors thinking they didn't include them onboard :-) Anyway - if I find the 2ohm is a little too much padding, I'll wire the extra 2 in parallel to give me just 1 ohm of padding.
    I'd like to get an electret capsule mic next and do some actual measurements. I'm replacing some older wharfedales (8" 2 way) which have ok bass but poor midrange (what attracted me to the AR.com DIYs).
    Cheers,
    Dave.
    Sep 2003
    TX, USA
    Heres a picture when I first started the boxes. When I have finished them I will post the finsihed product. This is my first time trying to get pictures up here so hope it works out.
    There's that plywood...looking good Paul. Looks more organic than the 4 baffle-less boxes I've got.
    Just remember, before you start brushing your teeth and fixing your hair in them shiny black boxes, send us a few pics.
    Sep 2003
    TX, USA
    Sanding lacquer on my first box and....
    i sanded through to the primer. Triple darn da*n. It was a very small spot so I thought to myself just leave it there, it's fairly inconspicious. I showed my wife my work and guess what? The first thing she said was what is that white spot there. Jeez. So i put some more enamel on the spot and hopefully it will feather out nicely. If so, then I will put another light coat of lacquer and begin the sanding, compounding, and polishing again. But I have to say that the box did have that piano shine that I wanted (shaving and brushing teeth in it look). So it's a long tedious process, but the payoff is a great finish. I just learned the hard way not to be so heavy handed when sanding the lacquer finish. Also, I thought I had them pretty smooth but when that lacquer goes on it tells the story whether you did or not. Well, I'll chalk that up to experience on the first box and hopefully the other four will go smoother now that I know what to do. This is taking longer than expected though so it looks like I might ( I stress might) be done this weekend if I can get all the other boxes sanded and lacquered before Friday. Have a good day! Paul.
    Doh, tough luck, Paul...man I'm some glad I decided to go with veneer. (we'll see how that turns out)
    I was thinking, for the PeeCreeks (which will probably go upstairs in the new office room) I might try a glossy red or blue colour for something different. If you had to estimate how many hours of prep, sand, and paint work you spend on each speaker after the cabinet is assembleed, what would it be?
    Sep 2003
    TX, USA
    Well....
    First off choose a oil based spray can enamel (unless you have a sprayer). The darker the color the more mirror like will be the finish. Dark red or dark blue should work out fine. I used rustoleum black gloss enamel from walmart. I just used some .99 cent equipment primer (about three coats). Let the primer coats dry about a day (you can cut it short if you dont put it on to thick) but a day is good for my region where humidity is always a problem. So expect to spend a 2-3 days priming and sanding the boxes. You want to the primer coat to come out flat and shiny. Then apply the first coat of enamel and let that dry for 3 days. Then sand and put another coat and let it dry for 3 more days. Sand again, and then apply the lacquer. The lacquer dries pretty quick so 1 day is a good dry time even though it says 30 minutes. I would say overall that I have spend about 10-15 hours in sanding. Here is an article that I used as the basis for the piano mirror look:
    http://linear1.org/gm/archives/00000157.php
    the looks like a geek but does wonders with finishing.
    Yeah, geeks build computers, cool people build speakers
    That 10-15 hrs sanding is for what, 4 or 5 speakers Paul? (please don't tell me 1 or 2)
    All by hand or can you cheat?
    Sep 2003
    TX, USA
    Hehe....
    After spending about 3 hours sanding the lacquer and compounding, and polishing 1 speaker I went out and bought a $39 dollar orbital sander from walmart that came with a compounding pad, buffer pad, and some sanding discs. I wish I woulda done that from the start. It's farily ez to find up to 400 grit sanding discs but it gets harder the higher you go so the final sanding will probably be by hand. The 600, 1000, 1500, 2000 grits. It would be nice to find a 600 grit sanding disc because thats used the most. The 600 grit is used to sand the enamel coats and the first pass on the lacquer. Once its smooth, you move up to 1000, then 1500, and 2000 on the lacquer. So yes, the orbital sander can save copious amounts of time and energy. Hand sanding is tedious work but I sure have burned off a lot of calories doing it. Needed to lose some weight and lower the colesterol level anyway. Oh, I couldn't find the higher grits at home depot, walmart, etc. so I went to a auto parts house. They will have it along with the fine cut compound and swirl remover. Oh, and don't get acrylic enamel, get the oil based gloss enamel. The longest part is waiting for the enamel to dry. You must let it dry before sanding or you will muck it up cause it will be to tacky once you cut through the inital gloss layer. Anyways, if you dont have an orbital sander go out and get one and save yourself a lot of time. I hand sanded all my boxes and it was a pain. My fingers still ache, expecially the right index finger LOL.
  1. High current design?
    By nahmed in forum Amps/Preamps
    Last Post: 06-24-2004, 03:56 AM
  2. AR.com drivers in an MTM design?
    By Swerd in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 06-01-2004, 09:44 PM
  3. Driver connections in MTM design
    By aimen in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 04-12-2004, 06:00 AM
  4. Anyone recommend a center channel to go with ar.com DIY's?
    By kexodusc in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 04-05-2004, 09:52 AM
  5. Why Bose doesn't get into Front-Firing speakers design?
    By Smokey in forum Home Theater/Video
    Last Post: 02-26-2004, 05:27 AM
