Results 1 to 25 of 33
Threaded View
  1. #3
    Aug 2004
    Anybody have any info on this? Like what frequency is it set at, etc...
    Not much is said about it.
    Anybody have a frequency response plot of this speaker with the newest crossover specs?
    I estimate the xover frequency to be 2,600Hz. I put the new xover (with 2Ohm resistor to pad down the tweeter a bit) into speakerworkshop out of interest. (The frequency plots are based on infinite baffle - I don't think I linked it to an enclosure so don't worry about it dropping away from 150Hz down....above 500Hz is indicative.)
    Please note - these are estimations, modelled on Peerless' published frequency and impedance graphs (not measured). also - I don't know why but I had to invert the tweeter to avoid a null @ xover (as you'll see in the xover diagram) - not the case when you build one....
    Cheers,
    David.
  1. High current design?
    By nahmed in forum Amps/Preamps
    Last Post: 06-24-2004, 03:56 AM
  2. AR.com drivers in an MTM design?
    By Swerd in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 06-01-2004, 09:44 PM
  3. Driver connections in MTM design
    By aimen in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 04-12-2004, 06:00 AM
  4. Anyone recommend a center channel to go with ar.com DIY's?
    By kexodusc in forum The Audio Lab, Tweaks, Mods, DIY
    Last Post: 04-05-2004, 09:52 AM
  5. Why Bose doesn't get into Front-Firing speakers design?
    By Smokey in forum Home Theater/Video
    Last Post: 02-26-2004, 05:27 AM
