Results 1 to 25 of 42
    Quote Originally Posted by dave_bullet
    I'm not sure I'm qualified enough to answer you question. It would seem to me that you could get some undesireable effects from standing waves, etc if you increase the interior volume of the "top part" of the cabinet by dropping that partition. I know some people have made larger cabinets for these with poly-fill, acousta-stuff, etc, and reported good results. I think you would want to keep the 13 inch height the same, at the very least, and maybe use bracing every 8" or thereabouts to limit resonance problems. I wouldn't want to go much more than 13" without a brace.
    After a few discussions with some other people last night I think I'm going to abandon the sand filling idea and just use 3 or 4 "donut" and "H"-braces in the lower cabinet to cut down on resonance. Might stuff it with pink insulation, poly-fill, or something cheap so there's no "hollow" sound.
    DIY Dude poneal's Avatar
    Sep 2003
    TX, USA
    First coat of enamel on....
    Got all 5 boxes coated with the first coat of black gloss enamel. Dang they look good with just the first coat (I can see my self in them). I have to let them dry for 3 days then sand and put the second coat, wait 3 more days, then sand a clearcoat, then wait 3 more days, then compound, swirl remover, and glazing. Can't wait.....
    Great so in 10 days or so you'll have some pics up for us, right?
    Paul, what speakers do you own currently that you could give us a head-to-head comparison with when you're done?
    Man, I can't wait to get back at this...moving company is coming on the 9th, hopefully by Monday, the 13th I can get back at them...
