Results 1 to 25 of 107
    Linear Guy
    SW Pa.
    aftermarket power chords
    I am thinking about purchasing 3 aftermarket power chords. An internet site is offering 3 ft. 12 ga ptf shieldied wire with connectors that everyone seems to think are good. The price is around 100.00 each. Seems like a fair price for the products. I am not interested in replacement power cables from speaker cable companies at several hundred dollars each. Questions are: 1) Am I likely to detect any sonic upgrades from doing this and 2) 12 ga seems like an overkill in wire guage.
    system
    Gallo Reference III Speakers
    Van Alstine Pre (ss)
    Van Alstine Power (ss) 220w
    Cambridge Audio 640 CD deck.
    Magnum Dynalab Tuner
    AQ diamondback interconnects
    AQ Bedrock speaker cable.
    your thoughts...... thanks, dk
    Hummm?? Le' me think ...
    Quote Originally Posted by daviethek
    $300.00. That's 42 Naxos discs at $7 each from Archiv Music ... or 60 at $5 each if you download them as you can, or soon will be able to do.
    The choice is easy for me.
    If you are not sure about the benefits I would not buy 3 at once. I use the PS Audio power punch with my Cambridge Audio Azur 640 and notice a deffinate improvement. Better dynamics and smoother sound. The cable is $49.95 from several sources such as Audio Advisor. It is very well made and even has a removeable ground plug if you develop a hum problem. I would check them out for a 12 guage power cord.
    Linear Guy
    SW Pa.
    solid suggestion, thikk I'll try it. thanks. dk
    The Collector
    Sep 2003
    Springfield, MA
    I would make you own power cords, some good quality 12/3 and a good quality edison plug like the Leviton ones, and a good quality IEC plug. To get the same quality of a $100 one you should be spending about $18 to $20
    What I've tried
    I'm very sceptical about power cords based on my limited experience.
    I tried a PS Audio Power Bunch with my Panasonic SA-XR25 "digital" receiver -- made bugger-all difference.
    I made my own PCs using Wattgate connectors and Belden cable for use between the wall and my PS Audio Ultimate Outlet and between that an my Bel Canto amp -- again, there was root-of-dick-all difference.
    (By the way, the Ultimate Outlet makes not perceptible difference either.)
    Pat
    Pat is offline
    Nov 2005
    Indianapolis, Indiana
    I've made my own heavyweight 10 gauge powercords with with material from www.partsexpress.com They work fine and I can make them any length I need.
    Have a good day.....Sez' Pat
    Denon 685 Receiver & 2900 Player, Sonographe 120 Amp, Klipsch RF7 Speakers, 2039+ svs Sub, 10gauge solid core copper cables
    Quote Originally Posted by Pat
    Next time, try the Belden 83803 double shielded cable available at PE for high RFI generators like CD / DVD players.
    Pat
    Pat is offline
    Nov 2005
    Thanks,
    I wasn't thinking about sheilding at the time.
  2. First experience with power conditioning
    By Mr Peabody in forum Cables
    Last Post: 06-20-2006, 08:09 AM
  3. Question on ac power supply for power amp
    By hkhurana in forum Amps/Preamps
    Last Post: 11-08-2004, 01:30 PM
  4. Should power cords be shielded?
    By Tony_Montana in forum Cables
    Last Post: 07-16-2004, 10:45 AM
