Results 1 to 7 of 7
    Feb 2004
    Thanks for the suggestion. I will post there as well. I was just wondering whether this was a common problem with this amplifier.
    Kofi
    MCH
    MCH is offline
    May 2002
    Just a quick note here. Have you checked if the speakers are actually ok? Played them through another setup to make sure there is no problem with them. I had a problem with a speaker that had a bad interenal connection. I thought it was my amp also. But turned out to be the speaker.
    my .02 cents
    None sam9's Avatar
    CA
    There are a lot of things it could be but since it happens with a low input signal. I would guess that the amplifier circuits are not getting the voltage they should from the power supply. My reasoning is that if something fails in the amp circuit, itself, the result is most frequently a short which causes protection circuits to shut everything down. The fact that it will play at low levels without triping the termal indicaior suggests something amiss in the power supply.
    In any case this is not likely to be something you can fix yourself without a schematic and some experience in diagnosing problems inside the enclosure.
    http://www.drachen-audio.com
    Feb 2004
    yes, I have checked to make sure it's not the speakers (they play without problems on another receiver).
    Yes, I suspect it's the power supply section. Someone else has suggested rail fuses so I'll check those as well.
    I'm fairly comfortable checking the circuit with a schematic. I should have one soon.
    Thanks
    Kofi
    Feb 2004
    Problem found...it turned out to be a couple of blown rail fuses. Thanks for all the responses.
    Kofi
  2. First experience with power conditioning
    By Mr Peabody in forum Cables
    Last Post: 06-20-2006, 08:09 AM
  3. Question on ac power supply for power amp
    By hkhurana in forum Amps/Preamps
    Last Post: 11-08-2004, 01:30 PM
  4. Should power cords be shielded?
    By Tony_Montana in forum Cables
    Last Post: 07-16-2004, 10:45 AM
