Results 1 to 25 of 119
    Jul 2006
    That looks like an awesome design indeed!
    I agree with Kex though, brace it, brace it real serious!
    what glue are you going to use to glue the layers to each other? whichever you use, be sure to do only 2 layers at one time, and clamp them, as good as possible, you don't want any holes in the glue...
    btw, are you leaving the walls like that? or are you planning on using a filler of some kind (or cement, which might be more appropriate ), to make it a smooth/real egg like enclosure?
    Good luck, and don't cut your fingers of
    Keep them spinning,
    Bert.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    Keep them spinning,
    Bert.
    Thanks Basite,
    I will be cutting the disks at angles to match the curvature of the egg. Then lots of sanding. No filler.
    I have 10 fingers today. My plan is to still have 10 fingers next week. Keep your fingers crossed for my fingers.
    Jul 2006
    Thanks Basite,
    sounds like you have a plan
    here's some more inspiration btw: link to an egg speaker!
    Life is music!
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-304
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Cool. I especially like the ports in the stand. Nice.
