Brandonh,
I would be EXTREMLY reticent about using pro amps in a home environment. These amps(which sounds pretty good in clubs, open venues, and in mixing studios) does not have the same imaging capabilities, low noise floor, ability to reveal detail as amps for home use. If you are looking for nothing more than power, then this may be the way to go. If you are looking for power with finesse, look into Cinepro, or used Cal audio labs amps. I have used both at my studio and my hometheater at home, and I assure you they have all the power you need, with the finesse of a audiophile grade product.
