Results 1 to 7 of 7
    Feb 2004
    on some faraway beach...
    See if the hum goes away if you just have one IC connected between CD and pre. Might be a grounding problem on one of the inputs, so you develop a ground loop in the IC returns since they are at slightly different potentials. Or just take your ohmmeter and verify both input grounds are solid, and that they are physically tied closely together. Sometimes the input returns are also isolated from the chassis ground with a resistor to break potential ground loops.
    It happens with any input and any component I plug in.
    I'm not sure how to meter the inputs for ground, but thanks for the reply.
    Feb 2004
    Might not have been very clear, but by "one IC", I meant either left or right channel, not both. With both left and right connected, there is a loop established if the two input grounds are at slightly different voltages, so if it still occurs with just the one channel connected then we can rule out that potential issue.
    Update
    Wow, I was just poking around doing a Google search for my Hafler 945 to see what it's worth at this point and cam across an old thread from here where I was complaining about the same problem. I guess I totally forgot about it's issue and put it away for years until I tried using it again last summer when I started this thread.
    From the Archives I found this from 2002, 10 years ago....
    "You don't know what you have till it's gone! HYFI
    Jul 15, 2002 9:11 AM
    I am just wining here about my system. After I waited 8 weeks for my Stratos amp I was in audio heaven. But only for 3 days. On the fourth morning I fired up the rig and my pre-amp started blowing it's fuse. Transformer or power supply shot. So I hook up my old Hafler pre-tuner and get nasty hum out the speaks with the Stratos. Pluged my cd player direct to amp to make sure amp was ok and it was. I can't run that way since my cd player starts it's volume at max everytime you power up. I can see the speakers smoking in my head as the wife hits the play button. So now I am back to the system i replaced. Hafler 945 pre tuner and 9180 amp. Seems the Hafler pre has a grounding problem so all i can do is use the Hafler amp and a cd player. If I plug anything else into the pre I get the same nasty hum through the speaks. So now I am in audio hell until my real pre gets fixed. So now I can really appreciate the system I built after being forced to listen to my old one for now. I almost don't even want to turn it on. I guess I am spoiled. Oh well!
    Bruford is coming soon.
    Brian"
    Well it's finally been diagnosed and I will pick it up on Saturday. It did have the following issues so there was not much I could do about it.
    The pre-amp has 2 bad capacitors and the output connectors are corroded and the in line 2 resistors changed value.
    They have to remove everything to repair it but I will be glad to have it back in the system and in case I decide to sell both the Pre and Amp as a set and buy some Chinese Dime Store Gear to play with.
