Help me diagnose a nasty ground loop issue
I have an older set of Hafler 945 Pre-Tuner and a 9180 amp. I recently had the amp gone over and cleaned/calibrated to get rid of a hum.
After getting it home and hooking thins up with a CD player, I get a real nasty buzz in the speakers. So now I figure I have a problem with the Pre. I took it to the shop and they bench tested it on the spot and it appeared to be fine by itself however he hooked it up to the oscilloscope so I took it home and hooked it up. With just the pre and amp plugged in and connected, all is fine but after cabling the CD player and plugging it in, the buzz is there.
Below are the steps I took:
If the Pre and Power are connected only, different outlets, same outlet, or with amp plugged into pre, Tuner (within pre) is just fine with no buzz.
As soon as I connect any other component to the pre (any input) and plug that in-not even turned on, same or different outlet, that is when the buzz happens.
I also get the buzz if using a 3 to 2 prong adapter no matter where the amp is plugged in.
I have used a DVD player and VHS to rule out the DVD.
I used different ICs to rule out bad interconnect.
The only thing I have no tried is different IEC cords. Do you think that will matter or do can I still have a grounding problem within the pre?
Thanks for any input.
