So maybe going the wireless route is a bit premature. Thanks everyone that gave me some good input. What about the recommendation that "you should stick to the same speaker brand". I have a budget 5.1 system with Boston Acoustics front, center, and rear. Should I also to with a Boston Acoustics subwoofer? Best Buy is the only place I can go listen to speakers before buying (Now that Circuit City is toast), but they don't carry Boston Acoustics. Also where do you go to give a listen to a Martin Logan Dynamo?
