Hello
A few months ago i invest a mere $50 AU on a pair of beautiful floor standing technics speakers, and i matched them with high quality Jamo speaker cable, a very nice sound and bass, and sound seems well balanced, as I always like to hear all the sounds the music playback. They are around 3ft high (92cm), with 4 inch tweeter, 6.5 inch midrange and 12 inch woofer with vented rear port.
I have another pair of older technics speakers, they are closed and have a dome tweeter (richter brand) and horn midrange and 10 inch dia-ichi woofer.
Anyway, to my concern. I noticed that there are a few chips, and i noticed some lift of the veneer on those corners and the seal seems to be a little gapped. The pictures will explain what i mean. What glue or paint do you recommend to stop the process worsening?
Thanks in advance,
Regards
Sammy
