I am not sure what you are referring to here - are you talking about frequency response or volume level? If frequency response I agree.
I didn't post here to educate you. That's a hopeless cause.
Sometimes, it's hard to separate the dazzle that comes from brilliance and the baffle that comes from BS. I just jumped in here just to let the OP and the rest know that you're babbling on about stuff that has no bearing on the situation at hand.
One more time and then I'll let you have the last few thousand words. I'm sure I've made my point to those who want to understand and followed some of the links that Google provided.
It's simply that as volume levels go down, the human ear is less sensitive to low and high frequencies. A system that sounds good at a higher volume levels can and will sound "washed out" at low volumes. It's a simple, proven fact of human design that you seem to refuse to accept and, unless you're one of the X men, you're subject to the same physical foibles as the rest of us mortals.
No amount of words is going to change that. So, enjoy your ego posts. I'm outta here.
Q.E.D.
