Quote Originally Posted by modalnomad View Post
Thanks for the info! How did you know the part I found would be an exact fit? If it does I'll probably just do that. The binding post knobs are kind of a pain and I can't really see a cable having a good time hanging out there... I imagine the gold plating helps with conductivity as well?
The gold plating just helps with oxidation, nothing more. Making jumpers out of wire is your best bet and easy to do. You can buy spade connectors here at the bottom of the page in the link below.
Speaker Cable at Blue Jeans Cable
