my first subwoofer!!!
hey guys!! well im looking to buy a subwoofer to keep building my audio system...currently i have a onkyo nr609, a pair of PSB B5s(which i love) a NAD t550 as a cd player and a stanton t92 turntable.... im planning on buying the center speaker, but i heard that if im more in to music than to watching movies, i should go first for the sub... so that said ive been looking around and ive found a couple that ive liked... my budget is 250, but i think for this price i can get a real good deal... so guys can you give me any recomendations as to brands? watts? etc...
thanks guys i really aprpreciate it! im really excited of the system im building!!
cheers!
I would take a look at audiogon for a good used sub like this-
B&W ASW600 incl UPS Ground lower 48 states | Subwoofers | AudiogoN
I bought a used Martin Logan Dynamo sub for $300 on audiogon, the list price was $700. I would try to go this route for more bang for the buck. Be patient for a few weeks as new listings pop up all the time. That B&W sub above is a very good sub. It is non ported and will give you some nice musical tight bass. I would stick with musical sounding subs to pair with those B5's. Your PSB B5's will sound great with sub. I bought a pair of PSB B6's for my son. They really don't need a sub, but I gave my son my old Velodyne sub and they sound that much better.
Here are a few inexpensive New subs that would serve you well-
Amazon.com: Energy ESW-C8 8-Inch Subwoofer (Black): Electronics
Mirage Omni S8 Subwoofer - 100 Watt
Amazon.com: Energy ESW-C10 10-Inch 400 Watt Subwoofer (Black): Electronics
The Mirage and Energy subs are made by the same parent company and perform very well.
Thanks blackraven i will definitely look in to them.. actually i bought the B5´s because i didnt have enought at the moment for the B6´s, but later on im thinking of buying them and having the B5´s as rears... ofcourse it all depends on the budget, but for now im going for the sub, after that im thinking of a center speaker, probably PSB as well, so im getting there!!
thanks again!! and any other recomendations as for speakers, avr´s, cd/dvd players etc.. are more than welcome, i need all the help i can get to get the most on a budget!!!
If you decide on the B6's, and other PSB speakers, check out Saturday Audio
I bought B-stock B's from them and saved $100 on the pair. I cant even tell why they are B-Stock. Saturday Audio is running a sale on their B-stock PSB speakrs right now. They have the 2 PSB Image Center speakers on sale.
For a Budget AVR, look into Onkyo and make sure you get the model with the Preamp out so you can upgrade to a dedicated amp in the future and use the AVR as a preamp. For a CD player , I would consider a budget DAC if you already have a player with digital outputs. Otherwise look into the Marantz 5004 CD player.
thanks!!
actually i bought the onkyo nr609 due to recommendations, but im not sure if it has the preamp out!!
as to the PSB sale on saturdyaudio, i think im going for the C5 and the energy esw-c8, and hopefully will be satisfied with them! after that definitely im gonna save a few hundreds so i can get my hands on those B6 ive been wanting!
ill let you know how it goes!!
thanks again!
