low humming sound from subwoofer
Hi guys
just brought a secondhand subwoofer the velodyne cht -10 and it works fine. but i noticed it makes a low humming sound when switch on and on standby. should it do that i no the guy i brought it off didnt give me the proper power cord so i dont no if it could be that .or it could be a fault inside the amp or even the phono leads i just need to no as its doing my head in thank you
Do this before asking any more questions.
Turn the subwoofer off.
Unplug all inputs to the subwoofer.
Turn the subwoofer on.
Does it hum? Yes or no.
If yes, it's an internal problem with the subwoofer. Problem found!
If no, then turn the subwoofer off, plug the source back into the subwoofer, and turn it back on.
If the hum returns, you've got a grounding issue. Good liuck on this.
