Results 1 to 15 of 15
    AR Junior Member sgt bass08's Avatar
    Dec 2007
    England, UK
    low humming sound from subwoofer
    Hi guys
    just brought a secondhand subwoofer the velodyne cht -10 and it works fine. but i noticed it makes a low humming sound when switch on and on standby. should it do that i no the guy i brought it off didnt give me the proper power cord so i dont no if it could be that .or it could be a fault inside the amp or even the phono leads i just need to no as its doing my head in thank you
    I Perfer To Feel Bass On My Chest Then Not To Feel It At All
    Yonder
    Make sure your power cords and interconnects are not tangled up. I get occasional humming from my sub at times, and clearing the cords seems to clear it up.....
    Dec 2007
    England, UK
    no checked all power cords and interconnects they are fine.I noticed someone on this site as a velodyne cht 8 i wonder if he could let me know if is does the same thing as my thank you
    France
    It's probably a grounding issue
    Dec 2007
    England, UK
    hey up audio amateur
    wats a grounding issue like i said i checked all the interconnects
    Suspended markw's Avatar
    Do this before asking any more questions.
    Turn the subwoofer off.
    Unplug all inputs to the subwoofer.
    Turn the subwoofer on.
    Does it hum? Yes or no.
    If yes, it's an internal problem with the subwoofer. Problem found!
    If no, then turn the subwoofer off, plug the source back into the subwoofer, and turn it back on.
    If the hum returns, you've got a grounding issue. Good liuck on this.
    Quote Originally Posted by sgt bass08
    My guess is that he meant you may have a "ground loop" problem. I had the same issue when I introduced a Behringer EQ into the system for the subs. If it uses a three prong plug, try plugging it into a cheater plug to see if that helps.
    Dec 2007
    England, UK
    hi markw
    turned off subwoofer unpluged all inputs switch it back on still there so it looks like a internal problem .what kind off internal problem would you think it will be would it be worth fixing or getting rid off
    hi markw
    Dunno. I'm not a tech, but can you return it?
    Dec 2007
    England, UK
    I dont no i could ask him but i really wanted this subwoofer and i got it from another forum site like this
    Dec 2007
    England, UK
    Hi
    it could be but im crap when it comes to electrical stuff .i tryed using another three prong plug put it still did the same thing. the guy who i got it off said he had the same problem low humming noise but he said when he finshed using it he would switch it off by the power switch.
    Well, I give the guy points for honesty. It sounds like you knew it was busted before you bought it.
    Try and find a local tech to look at it, but don't expect him to do it for free.
    good luck.
    Dec 2007
    England, UK
    good luck.
    well no i asked him that after i brought the subwoofer when i realized it was humming .
    I'm pretty sure it was an "as-is" sale but, in your defense, I can't blame you for assuming that it worked fine.
    Now you know why I'm loathe to buy from strangers.
    Don't spend too much money on trying to get it fixed.
    Dec 2007
    England, UK
    Quote Originally Posted by TriMe
    is it a humming that can be heard from your listening area, or just when you are very close to the sub?
    Hi
    its lound enough to destrub me as i sleep not far from my bed and my room is really small plus i have had other subwoofer that dont do it. wich is why iam thinking its strange for it to hum like it does .but has xmas is here ive just orderd a epos m sub so the velodyne will be up for sale .
