I Need Help.
Hi All, I Was Just Wondering If You Could Help Me On This.
I Wanna DJ By Laptop, But I Wanna Get A Big Speaker. Like A 100-200watt Speaker
http://cgi.ebay.co.uk/Classd-CD12SP-600W-RMS-High-Quality-PA-Speakers-for-DJ_W0QQitemZ120446405081QQcmdZViewItemQQptZUK_ConE lec_SpeakersPASystems_RL?hash=item1c0b2a49d9&_trks id=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72 %3A1690|293%3A1|294%3A50
Like That For Example, But Theres 2 Sockets For Jacks In Them Speakers, So How Do Put 2 Jacks Into 1 Adapter?
Any Help? Thanks Ray
You do realize you're gonna need an amplifier, don't you?
Those are pro speakers and whe n playing in the big leagues, you play by their rules.
Those speakers use "speakon" connectors, a professional type that you can't find everywhere. If they have two then they are most likely set up for bi-amping so you'll actually need a powered crossover and two amps for each speaker.
If they can be run in a non-bi-amped mode the nyou'll only need one amp per speaker.
Whatever transpires, make wure whatever amps you choose have speakon connectors.
IMNSHO, IIWY, I'd be looking at powered speakers and avoid the BS.
