Results 1 to 15 of 15
    Dec 2002
    yes i check the connections all fine
    how do i check internal connections
    when i push it in while playing the scraping sound decreses or at low volume completly goes off but also the volume of woofer decreases
    but when the woofer is not in action, not connected to amp, not playing any thing, theres no scraping sound but when i press it in i hear the scraping sound, its like the cone paper is scratching something, if i push it justt from one side of the woofer theres no scraping, when i press from the opposite side there loud scraping, when i press from center theres a meduim scraping sound
    i noticed that if i pull the rubber surround a bit outwards from one side ( the side opposite to loud scraping side ) there a huge improvement and the woofer doesnt sound dull as it sounds when i push it in
    is this the correct/permanent way to fix it
    thx
    Aug 2003
    CC, TX
    scraping
    Sounds as if you overpowered your speakers a little. What seems to have happened is that the coils melted and became deformed (through mechanical failure, the coil would be scraping the magnet). Otherwise, this should not happen under any normal circumstance (or listening at moderate volumes, anyways). This happend to me before when I actually took a driver apart from a cheap speaker by seperating the magnet from the cone (for experimentation purposes). The coil actually melted the "paper" cylinder and caused it to scrape against the magnet. I wouldn't bother trying to fix it doing this, taking it apart you've pretty much ruined it. Buy better speakers that can handle more power.
    Or, when I was younger and couldn't afford a darn thing, I acually took a cloth and placed it behind the actual driver (between the spider and the cone) pushing it out a little to prevent scraping. My music seemed to have played fine and I noticed little difference...
    Dec 2002
    well i guess thats what happened
    it was used carelessly and was kind of over powered as well
    after pulling the rubber on one side i have reduced the scraping sound alot, at moderate volume average listner wont fell any annoying sound from it , one can only feel the differance while doing side by side comparision with other fine speaker, or at loud volume,
    well i think its not that bad
    while playing both at a time they sound fine
    thx
    regards
    You've learned one of life's valuable lessons. Everything has its limits and if you test them, you will find out exactly where they are the hard way. I am sure that sooner or later, you will buy another woofer or another speaker. In the meantime, your neighbors will enjoy a little less noise and a little more peace and quiet.
    The Collector
    Sep 2003
    Springfield, MA
    depending on the brand you can get it reconed and coiled. what brand is it? also don't push against it while it is playing, remove the driver and evenly push into the cone and lightly light it from the back. also tap the cone and check for spider fatigue. Has the speaker been dropped at all because the problem could also be a shifted maginet. or the can be something floating in the coil gap. Use a multimeter to check the impedence and bring it to a certified recone center to have it looked at and see if it can be repaired.
    Dec 2002
    thx all for ur help
    its not from any real good company
    its my car speaker made by some Japanese company called SENCOR
    its a cheap one, somewhere near 45$/pair
    no such think as repair here where i live
    just wanted to improve some car campany default stereo setup nothing special, just wanted a little more sound so added these 6x9 inch 3 way speaker and was been power my company default deck 45x4watts, before car only had two 4inch one way speakers in the front, added these in the back, the sound was nothing great but better than b4, these are 50watt RMS and 200watts PEAK, shouldnd have melted with 45 watts :-)))). although i never overpushed them , max volume i usssaully gave it for music is 25 out of 40 digit counter in deck. After that the sound starts getting bad and seperation of different frequncies loses, but it was overpowered at many times by some ppl such as my driver :-p
    anyhow im satisfied its working OK again
    these days i m hunting for HT speakers :-))))))))))
    regard
    thx
    Now you've learned another of life's lessons. Don't ever trust anything you value to other people. Even your best friend won't give a damn if he wrecks your possessions and it is very rare that anybody owns up to having damaged it let alone is willing to pay for repair or replacement. Just watch some of the small claims court TV shows and see how often this same situation comes up.
    My custom user title This Guy's Avatar
    PA
    Get a screw driver and take the woofer out of the cabinet. See if the wires connected to the woofer are on securely. Also, take a look at the crossover, just make sure nothing looks out of the ordinary. Does it make the scratching sound only on the woofer in question, or does it do it on the other speaker as well. Cause if you push the cone in over it's excursion limits, all woofers will make that scraping sound.
    -Joey
