Quote Originally Posted by swwdts
I went & bought another Kenwood passive subwoofer from BestBuy.I do not get upset w/ your reply.This is the well,you may not live here but,in the US free speech allows you to say how you feel & that is just how you feel.You did make a good point though.Thanks for your reply!
Sounds as if youre using a car subwoofer. Interesting. Did you bother to see if it would work within the parameters of the enclosure. Just because the ohm rating matches means nothing.
