Results 1 to 12 of 12
    Mar 2016
    Help connecting sub-woofer to vintage cr 820 Yamaha.
    Thanks for suggestions how to connect a sub-woofer to my Yam Cr 820 receiver.
    Rear Panel:
    AC Outlet Unswitched (2)
    AC Outlet Switched
    classicaudio.com
    Antenna Inputs:
    300 ohm balanced, 75 ohm unbalanced, coaxial.
    AM Ferrite Bar Antennaclassicaudio.com
    Phono 1 (L, R)
    Phono 2 (L, R)
    classicaudio.com
    Aux (L, R)
    Tape 1 Playback (L, R)
    Tpae 1 Record (L, R)
    classicaudio.com
    Tape 2 Playback (L, R)
    Tape 2 Record (L, R)
    classicaudio.com
    Speaker Out A (L, R)
    classicaudio.com
    Speaker Out B (L, R)
    The only way I see is to get a sub with speaker level inputs. Meaning you connect the sub to the speaker out of the receiver and into the speaker inputs of the sub. Not all subs have these connections.
    SVS and HSU make subs with speaker level inputs.
    Suspended topspeed's Avatar
    California
    Yup, like BR said, splice some wires into the speaker level out and hope your sub has speaker level inputs. Cambridge Soundworks also has speaker level on their subs.
    Mar 2016
    Thanks very much.
    Mar 2016
    Forgive the old school newbie ignorance but is this the type of input connection your referring to?
    Thanks again !
    Quote Originally Posted by Brad Steinfeld View Post
    Thanks again !
    No; this sub has a very simple interface designed to accept only a single, mono 'LFE' (low frequency effects) directly from an AV receiver.
    You would need a sub that has left & right speaker ('high level') inputs (to receive the signals from you amp or receiver) and left & right speaker output to convey the signals onward to you main speakers.
    The back of a subwoofer so equipped would look something like this: not the 'From Receiver' and 'Out To Speakers' connections ...
    Help connecting sub-woofer to vintage cr 820 Yamaha.-subwoofer-w.-high-level.jpg
    Mar 2016
    Thanks very much Feanor.
