Results 1 to 25 of 64
    Feb 2005
    Just dont get to stress out and get axiety attack ,life to short
    Yes, i am trying :-) Its quite tough...i think i will return to normal in August...
    Forum Regular PAT.P's Avatar
    Oct 2004
    ont ,canada
    Best thing is try to look for movers ( with muscle)with a flat rate.Try to look for storage near your place until you get your Barn or Flat .Sit down and smell the coffee or have a beer.
    Feb 2005
    Yeah, thats the idea so far since they dont fit through the door or window. Time to apply for a second job to pay the powerbill. The thing needs 8 power amps
    Oct 2004
    ont ,canada
    Flo that's what I do work 2 place (off at one for 8 weeks in summer but no pay) and spouse works also fulltime.We have 2 house (one is rented to my daughter) and trying to pay them as fast as we can while were young. Maybe you should charge a fee to go in listen to these when their set-up.Hydro is on the rise and becoming a problem in Canada .The drum-set wont take any power
    Philadelphia, PA
    Uh, Flo. You do know that I have nine foot ceilings. Hint Hint
    Ditto, also put in trussing to hold extra weight.
    Feb 2005
    Well i have to admit, things came differently then i had expected. This Apogee Grand has problem, like a buzzing bass ribbon (repair is close to 4000$), the electronic crossover has a small problem with the display. Amongst the possible problem of the Krell amps, i have decided differently.
    My idea was either Acoustat Spectra 6600 or the Dali Megaline. I have decided on the Dali Megaline! If i find a good Grand again, it will not be a problem to buy one since the ML retails at 40K, so reselling it and buying one is not a problem.
    Here is a pic ;-)
