Hi, I have a European Kenwood home speaker system that I bought in '04 while I was stationed in Germany. Is is made up of of FL and FR LS-9070-B towers, Center CS-7070, with SL and SR RS-7070. Kenwood doesn't even sell home audio in the states anymore and I am looking at getting in-ceiling speakers to upgrade to 7.1 surround. I can't afford to replace all of the speakers right now... I want to use the RS-7070's as rear L and R and get two in-ceiling speakers (budget around $250 or less) to be the surround L and R. How can I best match what I have with some in-ceiling speakers?
Specs:
LS-9070:
3-way 6-Speaker Wide Range System
Magnetically Shielded
Frequency response: 48 Hz - 30 kHz
Sensitivity: 83 dB
19 mm Dome Tweeter
Impedance 8 ohms
RS-7070:
2-way 3-Speaker System
Impedance 8 ohms
Maximum input power 130 W
80 mm Woofer x 2
19 mm Dome Tweeter
CS-7070
Terminal-Banana Plug Support
80 mm Woofer x 2
19 mm Dome Tweeter
Impedance 8 ohms
I also have a matching Kenwood Subwoofer, not sure the specs right now...
