Quote Originally Posted by jschaudel
Hello.
I am putting together a budget A/V system and would like some input regarding which subwoofer I should buy for $500 or less.
Thanks
Hi everybody! This is my very first post here-and what I am about to recommend may not set me too well with my fellow audio enthusiast's. First impression's, eh?
I have bought several subwoofer's over the past 6 week's. For under $500, beleive it or not, Sony has come out with an amazing dual 10" push-pull subwoofer called the SA-WX700. You get front firing and down firing in the same sub. I helped a friend of mine pick this one out, and I borrowed it for a couple day's to check it out. He didn't want to spend more than $200, but I talked him into this one ($259 @Circuit City- Print it off the web and the store will honor the price). It has amazing spec's, and it live's up to them. Zero distortion. "Tight and clean" as they say when describing great sub's.Loud and proud or soft and mellow-it is truly a fantastic sub. I know Sony speaker's as a hard and fast rule stink, but this sub is obviously designed in a whole different division. It is worth every penny-and if you don't like it Circuit City has an easy return policy. But I think you will be pleasantly surprised.
Perhap's the following observation will redeem me:
Now, if you are willing to spend another $100 over your $500 limit, the sub I settled on is the Martin Logan Dynamo. You can switch it to front firing or down firing, by moving the base around. When you use it in front firing, it comes with a grille you can attach. Although it is their "entry level" sub, Martin Logan doesn't make anything cheap. It sounds as good as their sub costing 2x as much (in my humble opinion).
