Built the Wild Burro Audio Betsys in one hour flat. These 8 inch full range drivers in the open baffle design sound better than speakers costing ten times their price. These things are so easy to build a ten year old could put them together. If you don't have an unused sheet of plywood sitting around buy one from HD and they'll make all the cuts for free.
If you've never heard a good single driver in open baffle you're in for a shock. The Betsys are so efficient they match well with a T-amp or 2.5 watt SET.
