• 01-10-2008, 01:50 PM
    ericwagner
    12" 4 Ohm Woofer Info/Help Needed!
    hi
    new to your site
    very nice site
    i am an inventor (real job is a plumber)
    i built a nice digital jobsite boombox already (can email pics if requested))
    Boombox is a larger style of the old 80's Breakdance Boomboxes
    All Plexiglass construction w/ a handle
    Has an Ipod for Signal, a 2 channel DJ amp (rack style - on top) w/ a bass blocking crossover (recessed into rear of box) powering 2 Bose Cubes (from a sorround sound set), & a 1 channel Bose Sub plate amp powering a 12" Pioneer Sub
    very heavy/bulky, but nice as hell
    so.......
    I need info/suggestions about a 12" - 4 Ohm - Handling 350 W RMS woofer (rating of plate amp i will use on next build):
    a good/loud/clear free air woofer or 1 that requires a small volume enclosure
    to be used playing rock/pop type music at meduim to high volume
    im trying to keep the size & weight down on my next boombox; after all it will contain 2 amps, 2 Bose Cubes, crossover, etc.
    trying to make the jobsite boombox smaller/lighter/better etc.
    any info is much, much appreciated
    eric m. wagner
  • 01-10-2008, 02:09 PM
    GMichael
    Woofer or sub-woofer? I am going to assume sub.
    Lots of choices here. http://www.partsexpress.com/webpage....ctGroup_ID=487
    I would go with this one for it's great sound quality. http://www.partsexpress.com/pe/showd...number=295-464
    This one for more output http://www.partsexpress.com/pe/showd...number=295-466
    Or this one for just sheer power. http://www.partsexpress.com/pe/showd...number=295-404
    There are better drivers out there, but these represent a good bang for the buck.
  • 01-10-2008, 03:03 PM
    royphil345
    I don't know how a 12" woofer would sound with Bose cubes. The Bose woofers are smaller, partially because the cubes have a very limited frequency range. A 12" woofer probably would leave a large "hole" in frequency response between what the woofer and Bose cubes could produce. The result would probably be a thin sounding system that's missing the all-important midrange.
    You might want to look at smaller woofers and build ported boxes to the recommended specs for the woofers... or look at some kind of 2-way speakers with 6 1/2" or 8" woofers to replace the Bose cubes. Possibly 6" x 9" or other coaxial car speakers...
