Well, Sorry I can't be of help with the CD player but I can tell you that the iPod pre-set EQ settings have quite a variety to them. As well, other MP3 players that actually allow you to adjust the EQ yourself might be something you could look into, though from my experience these are often just 2 band EQs. For instance the Insignia, Best Buy's brand MP3 allows for custom EQ settings.
Good luck on your search.
Thanks for the suggestions. I hadn't thought about portable mp3 players with equalizers, but since there have been no postings on possible CD players, it might be the way to go. I have seen some upper end players with more than the two bands equalization you describe, and paying a little more for that feature as well ability to plays some of the lossless compression formats might in the long run actually be a better way to go than a CD player that can only handle CDs and CDs with.mp3 files. I also suspect that in most cases a higher end player in general is apt to have a flatter response if it has the ability to add bass for those that want that sound. At least I hope that is the case. The fact that it would hold more music files than a CD if the capacity was greater then 700 mb would also be a plus since you wouldn't have to change CDs.
Thanks again for bringing me up to speed.
