Results 1 to 5 of 5
    Jun 2010
    bangkok
    headphone amplifiers - which is best?
    I'm looking for a high quality headphone amp for less than 200 euros.
    Does anyone have any recommendations/experience??
    Thanks...
    frenchmon frenchmon's Avatar
    St. Charles Mo
    have you tried http://www.head-fi.org/
    I'm sure they have lots of sugestions.
    Mar 2010
    if you are still looking...what headphones do you plan to use it with? I could make a much better suggestion if I knew that tidbit of info.
    I have reviewed three headphone amps. on my site that fit your budget...you can check them out here: http://www.best-headphone-review.com...eadphones.html
    Hope this helps
    Passionate Headphone Enthusiast
    Owner, best-headphone-review.com
    Jul 2007
    mia fl
    Headphone_Guru@quote
    True!!
    and I love your review of the 'ZERO' in the "link above, its truly a 'common sense buy!! below is (my 09 Zero version) it dose a great job with all my Cans from anyone of the input- usb,coaxial,optical, in the pic. I'm trying the analog out with the Musical fidelity V amp that i picked up cheap from A,A. they rocks the SENN-600 nicely
    Chet Baker-Trumpet
    Pepper Adams-Baritone Sax
    Herbie Mann-Flute
    Bill Evans-Piano
    Jun 2020
    Wanneer heb je voor het laatst van seks kunnen genieten? Als u bent vergeten wat goede seks is en lijdt aan erectiestoornissen, kunt u Viagra op die website tabletten gebruiken op die website . Slechts één pil is genoeg om al uw problemen op te lossen. Succes!
