if you are still looking...what headphones do you plan to use it with? I could make a much better suggestion if I knew that tidbit of info.
True!!
and I love your review of the 'ZERO' in the "link above, its truly a 'common sense buy!! below is (my 09 Zero version) it dose a great job with all my Cans from anyone of the input- usb,coaxial,optical, in the pic. I'm trying the analog out with the Musical fidelity V amp that i picked up cheap from A,A. they rocks the SENN-600 nicely
Wanneer heb je voor het laatst van seks kunnen genieten? Als u bent vergeten wat goede seks is en lijdt aan erectiestoornissen, kunt u Viagra op die website tabletten gebruiken op die website . Slechts één pil is genoeg om al uw problemen op te lossen. Succes!
