I'm getting confused. I want to run my subwoofer flat. The same level as my surround speakers.
I've read that the Radio Shack Analog meter is inaccurate at levels under 80hz, and that the Sound and Vision sub tone is at 40hz, which means a variance of -2.5db.
So, I set my sub level to 83db, while the rest are at 85db.
But then, I come across this forum, and you are stating that the sub should be set 2-3db HIGHER than the satellites?
Anyone know for sure? Any good reference sites I can check out?
Thanks.
