Results 1 to 15 of 15
    sacramento (carmichael) CA
    thx.. i haven't unplugged; just turned it off for a few min. it always starts back up fine. maybe unplugging would reset something? as for de-dusting... haven't done that, but worth a try. i just wonder if there is some weak link in the internals. bad cap or something.. but i'll try your suggestions this weekend. if not that, there are a couple service centers in town.
    JSE
    JSE is offline
    Feb 2003
    Denial
    A couple of suggestions,
    - check for phase
    - make sure no stray copper strands of wire are creating a jump between the speaker posts and receiver post.
    - check for damage to any and all cables.
    JSE
    asdf bjornb17's Avatar
    El Paso, Texas
    Quote Originally Posted by JSE
    - check for phase
    JSE
    i was going to suggest these as well. I would say that the stray copper strands could be a likely cause.
    in addition to those, are you trying to power speakers that have a lower impedence than what your receiver can handle? For example: 4 ohm spekaers on 8 ohm receiver?
    Dec 2004
    Cal
    Would a stray strand make it shut down or just sould like crap?
    Look & Listen
    May 2003
    NY
    Both
    Quote Originally Posted by shokhead
    You would be shorting the amps terminals. I did this once on a 400watt amp, luckily there was a 8amp fuse that fried first.
    Audio;
    Ming Da MC34-AB 75wpc
    PS Audio 4.5 preamp,
  1. JBL's Internal Monster Wiring
    By okiemax in forum Cables
    Last Post: 07-14-2004, 09:44 PM
  2. BUYING A New AV Receiver? Let me help and so can you!!
  3. Subwoofer placement vs. room modes (standing waves)
    By Richard Greene in forum Speakers
    Last Post: 02-27-2004, 05:40 PM
  4. Question regarding SACD connections
    By Tyler in forum General Audio
    Last Post: 01-29-2004, 05:03 PM
