Results 1 to 25 of 27
    Nueva Jork
    While there may be...
    Quote Originally Posted by Lane
    Looking for help finding the right receiver. I want to power speakers in 5 -6 rooms. Dont need a ton of power, but I do want very good sound. I'm thinking that a speaker switcher and IM volume controls will work so I wont have to go to a multiroom amp?
    ...some options one could cobble together, consumer level gear isn't really designed for these applications.
    As mentioned, commercial-type, multi-area systems from companies such as Russound or Niles are probably your best bet, as they have all the gear required to do what you want.
    jimHJJ(...good luck...)
    Feb 2006
    Great info - thanks for the help. As suggested, I'll try to explain what I"m after more clearly....
    This is not a commercial application and I don't need multi source audio. I only want to be able to get audio, from one source at at time, throughout my house. I plan on in wall/ceiling speakers - 5 - 6 pair and none of them need to be huge. Not looking to rock the house, just to get nice sound throughout. What I have learned so far is that I can do this with a speaker selector and IM volume controls - but thats what I'm trying to clarify. I would sure rather save the expense of a multi-room amp.
    First I've heard of the 70v speakers.... I'll look up the nuvo alternative
    Oh, budget? Hard to say - I'm hoping for under $2,500
    Feb 2006
    Still looking for help here.....
    I've looked into Nuvo - looks good - anyone have experience with them? Are there other alternatives that I should be looking at within my price range?
    I'm still considering the receiver/speaker selector option - don't know which is the better/more cost effective way to go...
    Thanks
    Feb 2005
    Thanks
    I have lots of experience with the Nuvo, it works well. I haven't heard any complaints yet. It is easy and clean. There are similar things, I think another one is either Denon or distributed by Denon and it may run a bit cheaper though the Nuvo should be right in the range your looking at.
    The power amp/speakers way should still be more cost effective. I did some comparing for you.
    Feb 2006
    Quote Originally Posted by ToddL
    I'm narrowing my decision and looking more closely at the Nuvo system. I wonder if I can get more info, maybe some first hand experience reports?
    I"m looking at the 4 zone Simplese - it looks like I can run two pair of speakers off a zone, if necessary, though with some reduced volume- anyone tried it? Also - its appears to have only two sources - is that true? If so, is there a way I can feed two sources into one input with a splitter - not to run at the same time of course...
    Thanks
