Quote Originally Posted by StateDJ85
PROBLEM FIXED!
I finally got the problem fixed. However, I've noticed something very interesting that was also a problem on my last Yamaha receiver. When going through the setup menu, the only way I can get bass out of the sub is selecting bass output to fronts+sub. When selecting only sub, NOTHING comes out of the sub, even with the sub level turned up all the way. Same with the setting to fronts (which of course I would expect). I don't understand why the only way to get bass to come out of the sub is to set it as "both" for the bass output. It doesn't cause a probem at all, I just don't understand why it works this way. Now everything else is flat, I've got the EQ set to parametric, and it sounds fine. I just dont understand why it doesnt work this way with the bass output set to sub only. With my old receiver, I knew the setup like the back of my hand, and had the same problem. Anyways, it's fixed so thank you everyone for your help.
When setting up a friends Yammie 1500. After doing YPAO and having the whole system calibrated, when we started playing a movie... no sub, no center channel. Had to go in and MANUALLY add those two channels to get the 5.1 to come through. Curious.
Da Worfster
