To say that FM is limited because it "only" goes to 15 khz or so is silly, most can't hear too much past 13khz.
Don’t forget about harmonics
Music are complex electronic waves that more likely have higher harmonics that go beyond 15 kHz or even 20 kHz, and FM limited bandwidth tend to filter out higher harmonics. That is why for high quality medium such as SACD, the noise filter (signal bandwidth) is set at 44 kHz instead of 22 kHz which is for CDs.
Limited bandwidth (15 khz) also mean limited Dynamic Range and S/N ratio.
I havent really thought about if digital radio sounds compressed because my expectations of radio are much lower than CD sound quality. Digital radio does sound very good and I enjoy listening to FM radio to hear old classic rock and roll and to see whats new in music.
Are you using a HD tuner (Sangean??) hooked up to your system or a tabletop radio?
