Results 1 to 10 of 10
    It depends on what you want out of a headphone (in your case, isolating in-ear earphones). The choices you listed are all poor value in terms of absolute sound quality, because they're in-ear phones which use hearing-aid technology which have certain limits to the sound... you're paying for the portability and superb outside noise isolation. An $80 Grado has better sound quality than a $200 Shure for example, but you couldn't use the Grados on a plane.
    Suspended markw's Avatar
    Quote Originally Posted by spago
    Why not?
    Feb 2006
    What would you suggest for good sounding headphones. I just wanted the best sound possible, mybe with noise cancelling so i dont have to blast it in loud areas.
    Aug 2005
    Quote Originally Posted by Rocker82
    Try Philips SBC HN060 Noise Canceling In-Ear Headphone
    That fits my tight budget $30 bucks!
    X
    Quote Originally Posted by The One
    How come every post by 'The One' links back to the same web company (warehouse123) ? Leaves me shilly.
    Why not?
    Grados are open headphones. This means they let in sound, and they let out sound. Because there's no isolation, it's pretty useless on planes... rather like using most other stock earbuds.
    Rocker82, I find the in-earphones that you mentioned absolutely perfect for air travel because no other category of head/earphone provides as much isolation. They really reduce fatigue on long-haul flights. But they are not the best you can get for the money if portability and isolation are not the main factors in your choice of headphones. Obviously though for portable use, these two things are very important which makes in-ears very popular.
    I'd recommend the Shure E4c and the Ultimate Ears Super-Fi Pro as fairly decent phones if you don't want to go custom. The UE's are probably more honest as far as the limits of this type of driver technology goes and throws out a slightly bassy, quite balanced sound, but the Shure certainly feels more resolved. Shure will come out with the E500 later this year, which is a triple-driver phone with an interesting add-on technology allowing you to selectively listen to outside noise.
    I have certain problems with in-ears for regular use, because the tips and even the custom mould ends up irritating my ears with frequent use. Which is why when I'm not flying I use the Sennheiser HD25-1 headphones which isolates well and are quite portable.
    nightflier
    Earbuds
    The E500's will be a big improvement according to what I've read. One of the dangers of in-ear phones is the physical damage to your ear-drums that can be caused by excessive long-term use. On planes this is especially dangerous because people typically turn up the volume to drown out the outside noise when using lesser-quality buds. If flying is a factor, spend some time reading up on sound isoltion technology as this will protect your hearing.
    As a side note, the best upgrade to any pair of cans is a headphone amp. This will improve the sound more than anything else because most internal (read: iPod) amps-on-a-microchip are very limitted so as to fit inside those tiny cases. Of course, when you're on a plane, a tube headphone amp is not an option, but a portable amp like the Bithead, or even the somewhat bulky Grado battery powered one, can really improve the sound. Paired with a set of good-isolating earbuds, this would be your best option.
