Results 1 to 25 of 28
    nightflier
    And also...
    Quote Originally Posted by Kevio
    The amount of average power you need does depend on how far you are from the speakers, how loud you want it to be, the efficiency and power-handling capability of the speakers. Believe it or not, 1 W average is actually reasonably rowdy.
    ...the type of music you listen to. Yes, most pop music is a little anemic on dynamic swings, but a well recorded classical symphonic piece will put much higher requirements on your gear.
    You source will also dictate what you should get - if it truncates the music or has high distortion, then it doesn't really matter what you've got down the line from there. Garbage in > garbage out.
    Forum Regular bjdalton1's Avatar
    Mar 2009
    I got some very good answers from everyone. I have a lot of distortion with this old little 15 wpc pioneer. It appears that power will help with the distortion I have. I need dynamic power. So what receiver do I get that is fairly new and has wattage 50-75 wpc. Kevio, the speakers won't smoke until I hit 120 wpc of which I would have to blast. I am looking for clean sound. I think i could stay in the 50-75 wpc range and get what I am looking for. What are my options boyz? What receivers? I want a little radio too.
