The console should have eq on it. If you want pre/post eq for recording and monitors you may need a second eq and you probably won't want to record the "wet" signals going to the monitors.
You may find the eq on the console will work to correct/enhance the recording feed.
Again, it's how you use the system. I would opt for a baseline eq for the monitors so you have something to work from when listening/recording different media/sources.
Get the receiver, put it together and play with it a bit to see what works best for your objectives.
