The type of output device per se isn't the issue. It is how the circuit is designed and most importantly, how it reacts to a given speaker's load. AN's are voiced using high output impedance amps which alters its FR as compared to low impedance amps (most SS). You need an amp that matches that characteristic.
The First Watt F2, for example, is one SS amp using MOSFET outputs that would likely work pretty well given its high output impedance (low damping factor).
First Watt F2
Good to know and interesting stuff. You really need to know what works best to find the right match.
Absolutely, although it really doesn't have to do with the country of origin! The VTL tube amps that sound great driving my stats fare poorly with the Advents in the vintage system. It is the speaker that determines the most suitable amp to drive it.
Yes, of course. I didn't mean that country of origin is the reason per se. It's the electrical characteristics of both amp and speaker that determines a suitable match. That said, I gather that many British speakers tend to work well with many British amps, as the Brits tend to favour certain ideals that extend across brands. Of course, it wouldn't be across the board, but in the entry level space you've got Rega, Naim, Exposure, Roksan and perhaps one or two more that work well with speakers from EPOS, Castle, Rega, Linn, PMC, Harbeth, etc.
