Results 1 to 9 of 9
    Jun 2004
    Question Unit on way..help
    I recently bought a "Sony CDP-CX455 " . I thought when it said "cd player" that meant it was like ...well like a regular old cd player. So now I find out that I am going to need to buy a receiver & speakers. It arrives tomorrow.
    What is the least amount any of you would spend on this receiver? I mean is there a big difference in these things? I only want to listen to cd's ...I don't dj or anything like that. I have speakers that I assume will work (ugh, another assumption).
    Please forgive my ignorance in this matter. I honestly thought I had bought something that would hold & play all 400 of those cd's.
    ANY help would be Greatly appreciated & thanks for reading this.
    Chatty
    My custom user title This Guy's Avatar
    PA
    Something like this would do fine. http://www.bestbuy.com/site/olspage....1&type=product
    You could also search ebay and get a used one for about $50. Really any stereo receiver out there with a brand name you heard of should suit you fine.
    -Joey
    yea that sony there would do you good, you'd have a nice mathing sony set.
    what were the speakers you have? floor standers or bookshelves? 2 way, 3 way? any stats you can throw at us.
    look for a label on the back of them to see if it says the impedance "Ohm" and wattage maybe even sensitivity.
    if the label is gone just get the brand and model number if you can.
    Jun 2004
    The speakers are "Altec Lansing Multimedia Computer Speaker System AVS500"
    There are 4 little ones & one woolfer/woofer (?). The sticker doesn't have Ohms, just that info & an address. They came with my old computer.
    The ebay search sounds like a good idea if I can't locate one in a pawn shop or something lol. Ebay is how I got myself into this whole thing, so the irony is priceless.
    It's not that I'm trying to be cheap, but I thought I was just upgrading my boom box. Didn't plan to buy a whole truckload of things.
    Thanks to both of you very much for your help.
    One last question (I hope)...is this receiver thing (that I need for the cd player) similar to what the tv deliverers hooked my tv/dvd/vcr/cable/surround sound to? Cause I was thinking maybe if it is the same, I could plug the player into that thing.
    PA
    Wait, if its computer speakers you can hook them up right to your cd player. And the answer to your second question is yes, but this particular receiever wouldn't do surround sound, just stereo (2 speakers). But your computer speakers wouldn't work with any receiver, because they have their own amplifier. If you want surround sound, you'll need a 5.1 receiver and regular speakers, not computer. So what you're going to want to do is connect the cd players audio output to the computer speakers Input. They same input that was used that went from your computer to your speakers. So you're going to need a cable with rca's on one end ( a red plug, and a white one), and the other end will probably be the same thing, or a 1/8" jack. I'm not sure which one it is cause all computer speakers are different. The receiver would be used if you had regular speakers, but it sounds like you don't even need one.
    -Joey
    Jun 2004
    Oh My Gosh! THAT is the best news I have heard!! Here I thought you would tell me I'm crazy & that computer speakers wouldn't work & I would have to buy other speakers in addition to the receiver! So, let me make sure I understand, I can just hook the computer speakers to the player & presto I will have music? I mean after I get the cables.
    ...holding breath about to jump for joy here
    PA
    haha yeah it should work fine. Happy listening
    -Joey
    Jun 2004
    Talking
    Super super super!!! I'm off to dance under the waxing moon, whilst singing the praises of Joey & Uncooked
    Seriously though, thank you both soooo very much!
    HappyWitch
    yea that should work,
    go into a radio shack or a similar store and pick up something like this
    http://www.radioshack.com/product.as...t%5Fid=274-369
    plug left and right into the rca input and the 1/8" stereo jack goes into the computer speakers.
    happy listening!
  1. Replies: 17
    Last Post: 05-17-2004, 02:02 PM
  2. The best of the two worlds. . .
    By Demetrio in forum Amps/Preamps
    Last Post: 04-11-2004, 09:53 AM
  3. Plasma TV Expected Lifetime
    By dapercy in forum Home Theater/Video
    Last Post: 02-25-2004, 03:15 PM
  4. problem with marantz sr6300 digital settings
    By victa1 in forum Home Theater/Video
    Last Post: 02-11-2004, 06:02 AM
  5. Need speaker selector unit advice
    By spyke in forum General Audio
    Last Post: 12-07-2003, 09:51 AM
