Quote Originally Posted by Freewillisdead112
I was thinking about doing that, but my computer doesnt have a cd/dvd drive or a good processor so I figure I have to get a new laptop for college so why not. The idea of the external HD would work out great after I got a better computer, as mine isnt exactly a prize winner.
Is there a portable that plays flac yet? Or is this still only a home file?
Thats my big issue, as music on the go is a big part of my time so If I put everything into flac, I would'nt be able to play anything! Honestly, I can't hear a difference In flac or 320kbs with my mach's as stated by alot of you, are not very accurate. I hear a big difference between bad VBR and 256kbs and under though. Its night and day. If I build these crossover-less speakers I will try the flac route, since they are told to be very musical and I would assume show alot of the bad traits In a bad bitrate file.
A good set of cans and an awesome quality recording will help you to reveal the flaws of 320kps. You're right though, when not under critical listening, 320, lossless, and CD can all sound the same...
