Tape input
Printable View
  • 07-01-2014, 04:04 AM
    chris9
    Tape input
    Hello guys,
    I've bought a pre and a power amp recently yet still looking for a cd player. While I am searching for a good one, I want to use my CD receiver as a temporary CD source. I checked out the back of the CD receiver and found an output with 2 RCA pins called 'TAPE OUT' (there is another one called 'TAPE IN' for you to connect it to a TAPE player and use the CD receiver as an amp). I wonder if I can connect via the TAPE OUT to my pre amp so the CD receiver be used as CD player.
    If I can't do that, would the headphone jack do the job?
    Thank you very much.
    Chris
  • 07-01-2014, 07:22 PM
    Smokey
    What is "CD reciever" ?
    If you mean headphone jack output to pre amp's RCA input, the answer is no. They have different impedance, so not a good match :)
  • 07-02-2014, 03:07 AM
    chris9
    So what about the TAPE OUT RCA plugs on the back of the CD receiver?
    CD receiver: an integrated stereo with CD playback, tuner, and amp function
    Google's result for CD receiver: https://www.google.com/webhp?sourcei...=cd%20receiver
    Thanks
    Chris
  • 07-02-2014, 04:24 PM
    Smokey
    Thanks for clarification
    You should be OK with that configuration. Audio RCA inputs and outputs are compatible cross all audio components :)
  • 07-03-2014, 12:49 AM
    chris9
    THank you Smokey!
  • 07-03-2014, 09:17 AM
    3db
    Hello guys,
    Chris
    Yes this will work.
    The tape out of the CD receiver provides a signal out which would be connected to the input of a cassette machine or in your case, to the input of the pre-amp. The tape in function is an input and is connected to the signal output of a cassette deck.
