• 03-10-2004, 08:40 AM
    piece-it pete
    Super tweak for any system!!!
    Hello everyone!
    Some of you know this one, many have heard of it, I'm here to testify that it works.
    Caigs' dynamic duo, Deoxit cleaner & Progold treatment.
    I used it on my "almost vintage" Hafler 110 pre, cleaning & treating every contact inside in out, including most importantly the switches/pots & the RCAs'.
    I had already cleaned the outside of the RCAs' using regular contact cleaner from the hardware store, and sprayed the inside of them, so I didn't expect much.
    Wrong!! As I was cleaning particularly the inside of the RCAs' with Caigs' handy Q-tip-like things I couldn't believe how dirty they were - filthy!
    So I finished up, hooked it up (marvelling at the smooth feel the connectors had, must be the Progold), turned it on, and.........nothing!! Took it back apart, found that I had mis-aligned a ribbon connector internally (D'oh!!), etc, etc, and lo & behold:
    It rocked!!
    No kidding, the sound was MUCH better! No snake oil, just Caig oil haha. More forceful, cleaner sound, it's just amazing. I wouldn't have believed it if I didn't hear it for myself.
    For around $50 you get a can of each & a bunch of the qtip things (I tried real qtips - too big), enough for all your equipment. Even if you aren't comfortable with opening your equipment do the RCAs. I am going to clean & treat every piece of equipment I own, including video connections. When I buy brand new equipment (it does happen occasionally:) I'm planning on treating all RCAs' & pots with the Progold, as it's supposed to inhibit corrosion.
    This is the stuff (scroll down for the qtip things):
    http://shopping.netledger.com/s.nl/c...t.A/id.2002/.f
    Try it, you won't regret it.
    Pete
    PS Standard disclaimer I have no connection to the company (that needs cleaned :) blahblahblah
