Results 1 to 9 of 9
    Village Idiot johnny p's Avatar
    Nov 2007
    SUBWOOFER Connection issue.
    Part 1,249 in my series of dumb questions:
    I looked at the back of my subwoofer so I could try to connect an RCA cable I have laying around to my subwoofer, and my receiver, and rid myself of the four speaker cables I'm currently running, and finally get true 5.1 surround...... here's the problem.
    The back of my Sub has Red/White Audio In, and Audio Out...... well, that's a no brainer, I'll connect the RCAs to Audio In right...... via Red/White....
    HERE's THE PROBLEM.... The back of my receiver has black RCA female parts, one port for Sub, one for Center, one for L, one for R, and one for each surround......
    WHAT???? Do I need a "Y" RCA cable to connect my sub?? I don't remember what the Monster Cable I purchased (and returned) was, but it might have been a "Y" deal..... Can I test my connection, or is it purchase the cable, and then see the results??? Am I connecting it to the wrong RCAs in the back of my receiver??? If so, I don't think there are any other places to connect the RCA to.... I'm gonna look again when I'm home, as I only crawled behind it with a flash-light, and didn't disconnect everything b/c I was lazy.
    Please help, and as always THANKS!
    Most subs will default to the left input. You can just run the one cable from the receiver to the left (white) in.
    Suspended markw's Avatar
    Ain't no big thang.
    You can run that one LFE/sub out to either RCA input on the sub, Some even say which to put it in but it really doesn't matter. Either one will work fine.
    But, if you can't sleep at night worrying about that other lonely, dejected, unused,d other RCA input, you can use a "Y" splitter to send the sub signal to both inputs.
    Get an inexpensive "Y" connector with one female RCA jack and two male RCA plugs.
    Out there
    Does your sub have a "line-in" RCA? It's a line level analog input. If not then GM's right, use the left input.
    Somewhere on Earth
    I think on the back of my Pioneer, it has a "Sub-Out" and its just one RCA jack.
    I'm not going to go down and check of course, but I'm pretty sure I remember hooking it up that way.
    Pioneer Reciever VSX-1015TX
    JBL Speakers
    Pioneer Plasma PDP-5071HD
    Xbox 360 (The Console to Own)
    Sony BDP-550
    DirecTV DVR HD20 Reciever
    1 Schnoodle
    2 Guinia Pigs
    Nov 2007
    yeah, one out on the receiver, and the sub has two ins (one left, one right) and two outs...
    They are "Line In" I believe..... is that different? Does that mean my Dinosaur of a Sub can't be connected by RCAs ???
    I need a reason to get a new one anyways!
    Somewhere on Earth
    Quote Originally Posted by johnny p
    Maybe yours doesn't have LFE? I think thats just the 1 RCA.
    JBL Speakers
    Sony BDP-550
    1 Schnoodle
    2 Guinia Pigs
    Some subs have the two inputs. Most default to the left. But you may be able to use either as Markw pointed out. Don't sweat it. It's going to work.
    Jul 2006
    in HT uses, the subwoofer is only ONE channel (mono), hence the name 5.1, so that's why there's only one rca output for the subwoofer on the receiver. with stereo material, the receiver will send all the low frequencies to the subwoofer, as a mono mix.
    as GM said, connect it to the left input on the sub.
    Keep them spinning,
    Bert.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
