sub placement question
Can i put my sub behind the AV cabinet? The AV cabinet is like a wardrobe, its quite big and is diagonally in the corner, the triangle space behind the cabinet is where i have put the sub, but it sounds different, too much higher frequency content. I have tried fiddling with the cut off but it doesn’t sound as nice as it did when it was in direct line if sight of the listener. Are their any tricks to hiding a sub behind stuff? or should they be in plain view?
cheers
kev
PS, can i extend my speaker cables afew feet but cutting and soldering into them? or is this bad ?
You can put the sub anywhere. You should LEAVE it where it sounds best. If you don't like the sound of it in a particular place, that's not the place for it.
Soldering is the best way to extend speaker wires if you have to. Just do it right with some good solder and a high end soldering station and wrap it with heat shrink.
thansk
Well i guess that makes sense, put the sub where it sounds best.
THe wife will be upset when i move it out into the room again.. Oh well..Thats the cost of good audio.
kev
