Quote Originally Posted by aevans
did you make any changes in your setup for this sound to show up, or did it just show up one day? another thing to check is of coarse the power outlet that is in use to make sure that it's wired properly. you can also reset your breaker in your fuse box.. which may help if it's gotten a really big load on it recently.
The noise has appeared since i changed my setup. Before i had the Krell Power Amp and PreAmp i had a NAD intergrated Amp which i didn't notice any noise.
