Results 1 to 25 of 26
Thread: Speaker Cables
    Jul 2006
    For low inductance, there is always Kimber 8TC at the top of your budget. DH Labs T-14 is a less expensive alternative with somewhat higher L, but lower than zip. There are likely many other good choices as well and I would recommend auditioning cables before buying or finding a dealer with a good return policy.
    agreed, I'm a big fan of Kimber too for speakercables.
    Life is music!
    Mcintosh MA6400 Integrated
    Double Advent speakers
    Thiel CS2.3's
    *DIY Lenco L75 TT
    * SME 3012 S2
    * Rega RB-301
    *Denon DL-103 in midas body
    *Denon DL-304
    *Lehmann audio black cube SE
    Marantz CD5001 OSE
    MIT AVt 2 IC's
    Sonic link Black earth IC's
    Siltech MXT New york IC's
    Kimber 4VS speakercable
    Furutech powercord and plugs.
    I'm a happy 20 year old...
    Feb 2008
    Thanks you two, I'll check out Kimber, and do some reserch. i appreciate the help
    Oct 2005
    HCM Audio usually has sales on Audioquest cables. They currently have the GBC speaker and Coral interconnects on sale. The GBC run $80 for an 8' pair. They have an aggragate size of 12 ga, which would be good for power hungry speakers. I use AQ GR8 cables I purchased from them several years ago on my Legacy Focus mains and Silver Screen center. Build quality is first rate.
    Charm Thai™
    Cleveland, Ohio
    Quote Originally Posted by bfalls
    I second the HCM audio suggestion. Been very happy with my audioquest GR8's bi-wire's and I have to imagine the GBC's are would be a good choice as well.
